N54 idle surge / lean out
bostons335i
19
Hey guys ,
Had a fast question to see if anyone has had this issue happen to them. Intermittently my car will be idling fine then all of a sudden hiccup like a misfire , afr goes lean (up to 18s) runs a bit rough then all of a sudden a couple moments later fix itself and run like nothing ever happened. All the logs with my tuning on WOT are completely fine . I’m going to attach a log where I caught it , the only thing I see that’s off is that fuel trims get maxed out while it happens. I did see in some options of MHD that it has a “AFR oscillation fix” I’ve been trying to figure out what that actually fixes but cant really find anyone using it . Thank you in advanced !
Ryan
  • P30_M5_R3_230804_1736doc14.csv
bostons335i
19
Additional information
FirmwareInterfaceJB4_MAC_AddressTMAP_VLearned_IgnDWPMethTriggerModeFFMethSafeModeMethAddMethScaleMethPSIE85_SetupVFF_Offsetfuel_30fuel_35fuel_40fuel_45fuel_50fuel_55fuel_60fuel_65fuel_70map6_15map6_20map6_25map6_30map6_35map6_40map6_45map6_50map6_55map6_60map6_65map6_70
30/139//2JB4 iOS 99153cc72d627a582.020.17503000990.0113275757575788080808015.014.115.016.017.018.019.019.019.018.017.016.0
BoostSafetyPID GainAutoShiftRedFuel_OLFUA1st_limiter2nd_limiter3rd_limiterOptionsN20_TMAP6CylModeLastSafetyduty_15duty_20duty_25duty_30duty_35duty_40duty_45duty_50duty_55duty_60duty_65duty_70et_enabledet_n1minrpmet_n1maxrpmet_n1ramprateet_n1mingearet_n1minadvet_n1minafr
26.02507000.00.00.00152505050505050505050505050000000.00.0
Judging by your log there is no electronic that is logged or a fuel related problem.
Looks like one of your sensors might be taking a dump which are not logged, you'd have to monitor all the sensors with one of the bmw tools
to work out the issue.
MHD is a great tool when everything is running right and to diagnose basic problems but that's about it.
Reactions: bostons335i
bostons335i
19
Hey , any idea what sensor could be going bad? Going through the forums I’ve seen some similar symptoms be caused by a bad /weak throttle body .
Also which bmw program is most used to see everything ?
