MHD 2.0 with Datalog API Integration
Nice job with the datalogs section. I've always just manually transferred logs to my PC then uploaded to datazap as the MHD integration was too much hassle but this looks like the way forward.
One suggestion would be a darker background similar to the datazap layout.
b4llistic
119
90
BMW N54
If you scroll down to the bottom of the page, there is a toggle for light or dark theme. If you're on desktop you can also make the page wide screen as well.
Reactions: carabuser
Nice and wide :sunglasses:
Another tip, if you go into someone's profile (click name and then click it again on the bubble that pops up)
You can scroll to the side and there is a tab for datalogs. You can see all the datalogs that user is showing publicly:
In this case you can see a couple of mine that are unlisted because I'm looking at my own.
Reactions: houtan
matreyia
1,780
711
335i e93
You can now upload datalogs with the MHD->SpoolStreet Integration available in MHD v2.0, there are two ways to proceed:
  • Upload logs with an API Key:
    • Logs will persist indefinitely at https://datalogs.spoolstreet.com/ under "Your Datalogs".
    • BB Code support to embed your datagraphs in posts and PMs.
    • Additional privacy options such as a true Private setting, so only you can view even if someone has the link
  • Upload logs without an API key:
    • Logs will automatically delete after 14 days, if you lose the link there is no getting it back
    • No registration required
If you want logs to be saved to your account automatically, click "Find" and you will be sent to the API Keys manager:
You may have to login/register and then go back to the app and click "Find" again to be redirected correctly. From the API Keys manager, click "Add API Key" in the top right:
Then select the graph:write API permission, add a name and click save:
Copy your API key:
Then go back to MHD and typed it in:
Once the API key is added, you will not need to login anymore and all the logs will be connected to your account automatically.
By default, logs uploaded without an API key will have the 'Unlisted' privacy setting. This means it won't be displayed to the general public, you MUST know the URL to the datalog in order to view it. This also means if you lose the link, it is gone forever.
If it wasn't clear how to upload a log, you swipe left on it.
To move your licenses to iOS, first login on Android then login in iOS.
If you have login issues, ensure you have Google Chrome downloaded on the device and use that browser to login instead. Don't use the phone's built in browser, just use Chrome.
Alternatively, try logging into the updated Android app with a different device temporarily just to get your licenses uploaded.
I hope someone does a youtube video of this stuff because it is all Greek to me. I am a moron when it comes to this computer jargon and internet procedures like posting logs etc... the other day I tried the new xhp interface and couldn't even flash the custom xhp file until after an hour of dicking around I found out that you have to put custom files inside of the xhp app folder. And the new xhp interface confused the hell out of me...was like, "where the hell did the custom flash button go?"....
Well, if you've upgraded already let me know if you're having issues I'll be happy to step you through it.
typedRew
412
221
2009 335i xDrive
i thought i did it right, but they wont automatically upload, i have to plug the api key in everytime
i know its something i did
They won't automatically upload, but once you click "ok" the log will go up without further interaction.
The API key should be saved in the box.
I have pushed an update to the datagraph software which is now live:
  • One-click create threads directly from the datalog. The Title and description of the datalog become the thread title and body
  • Share your datalogs automatically with your tuner. Enter your tuner's username in the Privacy settings and they will have access to all your logs.
  • Share individual datagraphs with specific people. Enter another member's username in the share field of a graph to give them access to just that graph.
  • Datalog category listing lookup via API. MHD and other apps have the opportunity to retrieve the available categories. It will be up to them to implement the rest.
  • Other changes to guest uploads and how guest uploaded datalogs can be linked to user accounts.
Share individual graph, in the edit graph settings:
Share all graphs in the user account privacy settings(Except private):
The person you shared with will see them in the "Shared Graphs" tab:
One-click create thread from graph:
The forum is predetermined based on the category the datalog is uploaded into. If you upload into the N54 Datalog category, the thread will be created in the N54 forum, etc. The thread title and body is inherited from the datalog title and description. Currently, the graph isn't embedded but you can copy the BB Code and edit the thread that was just created and add it yourself.
Please let me know if you find any bugs. I also updated the main board software and some theme updates.
1,620
I uploaded several datalogs yesterday using the API directly from MHD v2.03 and it worked surprisingly fine for me - somebody who thinks that API is an active pharmaceutical ingredient.
Of course my titles sucked since I wasn’t that careful remembering exactly what and when I was logging LOL:)
